Need help finding a Shipping company
JRSGN
A$$ deep
Does anyone know of a shipping company that will ship a motor?? I'm in CT & it has to go to ILL.
Jim
Hey Jim
I like to use FedEx Freight for shipping heavy stuff. They have a terminal in Milford. http://www.fedexfreight.fedex.com/l...S&shipperStateList=CT&btnsubmit=View+listings
Make certain your motor is strapped to a pallet and that it is stable. If your package is on the ground, you will need to specify a lift-gate truck. If it is on a dock, they will use a regular tractor trailer. Another thing to consider is that the driver can get access to the pick-up spot. Call to see if you can bring the motor to their terminal if possible.
HTH
Agreed with TRoGNman.
Also ROADWAY express will do it. Even cheaper if you bring the engine/pallet to a terminal in a pickup tuck.
I once sent a HUGE hamberger grinder machine to SAN FRAN from NHampshire. Terminal to terminal $87. weight was 200 lbs
I found a pallet free, Bought 3/4 ply & cheap 1x3x8' . You can use hinges from home depot pretty cheap. Pick up some Tie down straps for the motor. pretty easy.
shipping
DO NOT USE SBT ( small business transportation)
out of Merrillville,IN
took over 3 weeks to get shipped, and made promises they never kept!
blamed everyone , but still took 3 weeks to get picked up,
I have used Central Freight lines, were prompt, careful, and reasonable.
good luck.
cruzn57
