My buddy's 85 T-Type (Mods: Hotwired Walbro 307, Adj. regulator, ATR Up & Dp, newly welded headers, Big mouth cold air, 2800 Red Stripe, JL 93 chip) will not start and run. It was running fine, 55mph, when he tried to get on it and found more gas=less power and less gas=a tad bit more power. Lots of black smoke and missing. Now it won't even start without holding the pedal down and then it only sputters for maybe 5 seconds. It's not throwing any codes and the fuel pump stays on continously instead of priming the rail and cutting off when the key is switched on. I thought maybe it was the fuel pump or hotwire relay? Anybody know how to check one? Any ideas would be greatly appreciated.
