need help found some wheels but im confused
shocker998md
alright guys i found some wheels on craigslist and im kind of confused. It says works on s10's and chevy cars.
I looked up s10's bolt pattern and its 5 on 4.75 and that the cars are 5 on 5.
so do you think these will fit my buick, if so does the backspacing look good. These will be track only wheels, and ill run something skinny in the front and 275/60/15 MT drag radials in the back. thanks for the help guys!
Weld Pro Star Rims
Weld Pro Star Rims
The Buick's bolt pattern is 5 on 4.75.
Claude.
the bolt pattern is right- only the full size cars (Caprice, LeSabre, etc) with the HD suspension and the 1/2 ton 2 wheel drive trucks up to '98 had the 5X5 bolt pattern- but the rear backspacing would probably be a bit too deep for a TR.
