Need Help in Identifying Brackets (pic in thread)
I did the HB brake conversion and other maintenance...I have forgotten where the 2 brackets mount. Your help would be appreciated in identifying them, and a description of location...thanks
1 back of ac compressor bracket to lower #1 cyl header stud (with a m8x1.25 nut)
2 backside ear of alternator (slip 10mm bolt through front bracket then alt ear then through end and put nut on ) bottom to #1 upper header stud (m8 x 1.25 nut) and in middle to rear of alternator case (small m10 bolt in alt)
Thank you for the reply Paul...(my pic) #1 = #8 in the illustration. Where is #2 (my pic) in the Illustration?
.. your #2 is the #5 in drawing .. drawings were before production and doesnt show the arm to back of alt case
