I have a rollmaster timing chain set on the motor when I got it. The crank sprocket has multiple keyways and (2) dots on the thing. One is in line with a tooth, the other is at the base of the arc between the teeth. The mark on the cam sprocket is visible.
I didn't mark the sprockets when I removed the assembly (RATS !!) so now I need help. Can you help me identify the correct marks to set this up with?
