Need help! located in OKC
sorry for not checking up, had a long weekend! Found the problem yes it was the fuel filter. i guess it wasnt getting the right flow. Took it cruising over the weekend, the only thing is it feels like i lost power =((. but oh well thats another problem, probably needs to be tuned or something. What psi do you adjust your fuel pressure to?
If you have a TT chip,43. Commander or Extender,45. That's with the line off. Did you add WOT fuel in the chip? Do you have a filter with a replaceable element or did you buy a new filter? Did you find a noticeable amount of crap in the filter?
The old one you couldnt tell it wasnt replaceable. The new one is a russell brand replaceable one. and not sure about the WOT ill have to call Eric and see.
If your fuel pressure is set to 43 psi ( line off),your WOT pressure should be 43 plus boost pressure. If your fuel pressure ( line off ) is 43 and you run 20 lbs of boost,your WOT fuel pressure should be 63 psi.
