Need help !! Rusty roof
turbo nasty
Turbo Dojo / MNTR
Picked up a 86 GN and found quite a bit of rust on it.
Looks like I need a new roof.
Rust above both doors(water channels) through the metal and on the pillars. Also, around the pass upper corner of the windsheild and the rear window. Around the trunk seal is rusty also some all the way through.
what is the normal cost for replacing the roof/
I already have the interior stripped and the molding removed from the windows.
I am not going to get it painted just rust fix for now.
What do ya think???
I had an 83 Regal that had rust holes under the vinyl top and one of the better body shops in Orlando qouted me $500 if I brought in a good used one and did all the disassembly work(remove interior and weatherstrips). I figure with paint and materials it would be about $1000. Eric Fisher
$500 in labor sounds about right. If it was mine I would have the whole car painted at the same time though. Because the shop already is painting a big portion of the car and it would probably save you money in the long run. Cause you are not paying to paint the 1/4's and roof again.
