need help with a 85 gn
xippman
just got my 85 gn, does anyone have a vacuum chart or diagram? what about a wiring diagram? here is the prob. back of the motor where your vacuum block is there is a tee and one of the lines has a screw in it where does it go? on the driver side there is 3 sets of wire laying there with a cap on the is that extra? and there is a plate on the value cover that is broke off, does it have to be grounder? thanks for all the help Kevin
i am also building a motor and the picture in the forum / sticky isnt to slear on what goes where on the rear of the motor vacume wise if any one has better pics or can write down what goes where it would be very appreciated thanks in advance... anthony
On the rear of the motor there is 1 VAC port.
it comes from the FP regulator and then T's off at tis point - the other going to the boost sensor.
Hose routing looks like this :
Bst sensor --------------T------------------- FP reg
(pass side)..........(Rear of manif).......(front of motor)
...fender
HTH
