Some more Info about my car.
Turbo Trans Am 1989
Festival Car #118
MODIFICATIONS
INTAKE AND EXHAUST
4” K&N AIR FILTER & EASTERN PERFORMANCE 4” INLET PIPE
T72 TURBONETICS CERAMIC BALL BEARING 72 MM TURBO
TONY DEQUICK FRONT MOUNT AIR TO AIR INTERCOOLER
KENNE-BELL 70MM THROTTLE BODY AND INTAKE PLENUM
MATCHING 1” PLENUM SPACER
ATR EXTERNAL WASTEGATE & MANUAL BOOST CONTROL
CERAMIC-COATED STAINLESS STEEL FACTORY HEADERS
3” STAINLESS STEEL, CERAMIC COATED DOWNPIPE
3” STAINLESS STEEL CAT-BACK ATR “PITBULL” EXHAUST
ENGINE WORK
PORTED AND POLISHED O-RINGED CHAMPION HEADS
CUSTOM ROLLER-FULCRUM ROCKERS
CRANE 212/212 ROLLER CAM
CUSTOM ROSS 9.0:1 CR PISTONS
STEEL MAIN CAPS
NITRITE COATED STEEL CRANK
COMPLETE BALANCE & BLUEPRINT
A/C COMPRESSOR DELETE PULLEY AND BRACKET
IGNITION AND FUEL
“F.A.S.T.” BANK-TO-BANK FUEL-AIR-SPARK MANAGEMENT
WIDE BAND O2 SENSOR
MSD DIS-4 PROGRAMABLE CAPACITOR DISCHARGE MODULE
POWERMASTER 120 AMP ALTERNATOR
REAR MOUNTED OPTIMA BATTERY IN A MOROSO BOX
AEROMOTIVE FUEL PUMP
AEROMOTIVE FUEL PRESSURE REGULATOR
½” FUEL LINE
95 LB/HR MSD INJECTORS
SMC ALCOHOL INJECTION WITH BOOST SENSOR
FLAMING RIVER REMOTE BATTERY DISCONNECT
OPTIMA YELLOW TOP BATTERY
DRIVELINE AND SUSPENSION + EXTRA
SPECIAL SOFT COMPOUND GOODYEAR EAGLE TIRES (FRONT)
MICKEY THOMPSON ET STREET 28X11.50-15LT (REAR)
FORD 9” REAR END WITH DETROIT LOCKER AND 3.50:1 RATIO BY CURRIE
PST CARBON FIBER DRIVE SHAFT
KENYON BUILT 200-4R, TRANSGO SHIFT KIT & TRANS BRAKE
3600 STALL PRECISION LOCK-UP TORQUE CONVERTER
B&M CONSOLE MEGASHIFTER
SPOHN TORQUE ARM AND DRIVESHAFT LOOP
HOTCHKIS REAR SWAY BAR AND END LINKS
HOTCHKIS ADJUSTABLE PANHARD ROD
BMC STRUT TOWER BRACE
ALSTON WELDED IN FRAME CONNECTORS
KB SHOCKS
JEGS 6-POINT ROLLCAGE (MODIFIED)
HURST ROLL CONTROL
AUTOMETER BOOST GAUGE
AUTOMETER TRANS TEMP GAUGE
AUTOMETER FUEL PRESSURE GAGE
PROFORM ADJUSTABLE RPM SHIFTLIGHT
CO-DRIVER: CLIO THE CAT (CUTIE PIE)
That´s about it. Some of the stuff I don´t know much about. For example my fuelpump. It's an Aeromotive, but I don´t which one.
I can´t find any numbers or info on it and they all look pretty much the same.
Here is a picture on it: http://kiruna.d2g.com/photos/street&strip/23.gif
Turbo Trans Am 1989
Festival Car #118
MODIFICATIONS
INTAKE AND EXHAUST
ENGINE WORK
STEEL MAIN CAPS
IGNITION AND FUEL
WIDE BAND O2 SENSOR
½” FUEL LINE
KB SHOCKS
HURST ROLL CONTROL
