Need help with readings after engine rebuild
SpoolinV6Turbo
I spun the #6 main bearing at 46,600 miles so I decided to get it rebuilt and I finally got a scan master!!!! I would appreciate some help with these numbers on what’s going on with the car. I went to gnttype.org to obtain the references values and I’m still not sure if these numbers are good or not.
My readouts were taken with the engine warmed up, idle, and in gear.
O2- cycle from .203 - .785
AF- 07
L8- 56
bat- 13.2
Int- 127
bL- 105
clt- 196
ats- 141
r- 700
tps- .38
Iac- 0 <why is this??
cc- this goes 7-24-36-56-74-90-…..to 254 and the cycles again
I recently got the car inspected by the good ole DMV of NJ and passed with the numbers:
NOx- 0023
HC- 0051
CO%- 00.19
CO2%- 14.80
O2%- 00.40
RPM- 2011
My car has:
Bored 30 over
Comp Cam 69-248-4 cl-kit,it is a flat tappet w/212-212@.050&.459in.-.459ex.w/1.55 rockers w/ 112 lobe seperation
TA-49
8” Cone filter
Green stripe injectors
Flowmaster exhaust
Stock chip and intercooler
Sorry so long, hope anyone can help me
