78TurboMali said:Gaston has been a huge help through this and has been dealing with me over the phone and coaching me! I checked the fuel pressure today and a few other things that Gaston suggested. I ended up narrowing down the location of an air leak and with Gastons help and a little carb cleaner i found that the front of the plenum is leaking!! It has a leak straight across the front from end to end! I tried to snug it down but the leak is still there. I will order a new plenum gasket tomorrow and change it out once i receive the new one. I will keep you guys posted, see if we finally found the gremlin! i sure hope so!
I am glad to help you and will continue to. Now once you change that plenum gasket, you will need to set fuel pressure back to 43#, TPS to .42v, IAC to around 20v. Now you should see lower RPMs, lower BLMs (somewhere around 128), O2s around 750-850.
