SignUp Now!tybob said:hi ,what is the diference betwing the s2 block #25500012 and #25500013 i have a book by Dave emanuel and thay talk about the 25500013-017 -155 and 152 ,what about the other block number ? i see a block for sale on ebay (25500012)what is this block !
how mutch can cost a good s2 engine no turbo and injector only the engine complete !somethig around 700hp something to run in 9sectybob said:i am dicided ! i want to bild a stage 2 engine .....i plant to go whit a off center 4.1 s2 4 bolt main! i think the block part number is the 0017,heads are 0030,what i need to know is what is the crank i need ,the rods and the piston ! just to make sure thanks :biggrin: i know is a lot of question but there to many model and parts number....whitch one i need to make a good engine , and streetable !
49-blues said:#25500012 is a 3.8 stage1 block, #00016  are 4.1 blocks all off center like a production block. the #00153 are on-center blocks which are supposed to be the strongest. the stage1 blocks can have extra holes drilled at 12 oclock and 6 oclock to become a stage2, billet caps also play a big part in this.go to www.gnttype.org for a further break down of the different blocks.
the only complet motor i find here on the forum for sale are the one from anderson ! but i very dont think i can take this one for a street roller beast :biggrin: ill take a look thank for the info :smile:ijames said:There are two or three S2 motors for sale right now in the for sale forum - it is usually much cheaper to buy a motor than scrounge up all the parts yourself.
i see you have a lot of parts ! do you have a complet running engine 4.1l s2 274cc off center ! complete short block ,heads,intake....for the rest is ok !49-blues said:Have a look on ebay- i ve seen three lastweek.
tybob said:i see you have a lot of parts ! do you have a complet running engine 4.1l s2 274cc off center ! complete short block ,heads,intake....for the rest is ok !
49-blues said:I thought #0017 is a 4.1 block that they only produced 50 of in 1984 that had the chevy rear main seal. sort of a updated #0016 block? You can probably figure $10k-$15k for one done right.
49-blues said:that must of been revised after that cause i see no #0012 and #0016. which are shown on www.gnttype.org
hi its a nice short block but i want a off center engine !thank and good luck for your sale !BAGN said:I have a complete "NEW" shortblock for sale. More info here.
http://www.turbobuick.com/forums/showthread.php?t=191036
