need little o ring that goes on hard line to f.p. reg
turbo john FL
ITS ONLY A SIX SHOOTER
can anyone tell me where i can get one of those little o rings that go on the hard line where it screws into the fuel pressure regulator ? thanks in advance JOHN
actually tried napa , autozone nobody had any small orings like that to be used in gasoline , just regulat black o rings which ive been told will not last long
Harbor frieght has a o-ring pack. Has all the hard to find gm o-rings. I keep several kits here all the time. It's in a plastic box with tons of different sizes.
I've seen o-ring assortments in the "help" section at Autozone and other parts houses.... I believe the correct orings are brown.....
yes its a little brown o ring . im heading for a near by advance auto now and keeping my fingers crossed ; )
sent You the link for the feed at rail and the return under the regulator
These "hard to find o-rings" are readily available at almost any GM dealer. May be easier than dealing with dummies at parts stores. There are 2 sizes, a small and a large. Small on the return lines and large on the feed lines, including at the filter. Always a good idea to change whenever disturbing the connections. 10 bucks is cheap insurance over a fire...
FYI these 0-rings are the same as the ones from the TBI truck motors. I'm sure GM used that same style fuel line setup in everything. I think I even have a few here.
