Need more range on VE table.
3.8vsix
Guys I need a little more range on my VE, spark air fuel raito tables on my XFI. Just wandering what your numbers are on your tables. Mine are maxed out at a little over 21 psi. I would like it to reach at least 26psi.
They are:
249
240
230
220
200
175
149
125
100
80
70
61
49
40
30
20
Thanks for any advice!!
Although I need to rescale my kpa down for more resolution on my street tune, mine are:
290
266
245
225
215
190
165
140
122
107
91
77
62
53 idle in gear
40 idle in neutral
25
The first thought that comes to mind is that you must have a 3-bar MAP sensor in order for the higher scaling to work. If you confirm that, then go to the FAST HELP menu to get detailed instructions on what Disco Stu said. (As a side note to Disco Stu, I certainly agree with rescaling for more resolution in street tune; need a bunch more cells under 100kPa and very little between 100 and 200, and then going over 200 becomes critical as well. (For anyone that doesn't know, below 100kPa is vacuum, 100kPa is zero boost, 200 equals 14.7 psi and 300 equals 28.4 psi.... therefore the necessity of a 3-bar MAP; kPa is simply the metric equivalent of psi.) Your boost will climb really quick between 100 and 200, therefore very little resolution is needed, but under 100 is where all the driveability is so more cells are ideal, and then exceeding 200 becomes critical as well, so I like a few more cells in that region also in order to fine tune. Best of luck to you!
I just saw this thread. A quick fix would be to change the top three rows to 280, 260, & 240. Make sure you go into the Target A/F, VE, and Spark tables and adjust the values accordingly. If you have any questions, give me a call.
