I, myself, think that mygrain is on the right track. A draw thru I believe is superior to a blow thru system. Blow thru's have limitations of around 30 psi & DT has no such limit. Tractor pull engines used to see 100 psi of boost back in the 80's
That being said, there is two negatives to a DT system.
1. HEAT
2. LAG
BOTH can be easily & cheaply overcome. Especially compared to the high cost of intercoolers. IMO
![Roll Eyes :rolleyes: :rolleyes:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
(lol) intercoolers are restrictive, expensive & unnecessary.
The turbo industries want your $$$$
![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
They are an industry that promotes a heat pump to boost your engine, then advises you to buy an expensive intercooler to get rid of some of that heat. This is a inefficient method of removing heat and it restricts flow, reducing power & performance at LOWER rpm levels where it's needed. The whole principal is fundamentally backwards!
Also, most IC's are totally ineffective below 4,000 rpm where most of us spend our time driving & they are considered totally unessasary when boost is below 10-12 psi. like you plan to run on that Cheb.
I think your idea of building a water jacket around the intake tubing to cool the air charge is quite clever actually. I'll bet you'll be able to run a lot more boost than 10 psi also, it might suprise you. There are other creative ways I've seen ppl use to bring the heat of the charge down such as cold water systems that wrap the compressor housing & feed cold water into the intakes heat risers & air intake tract. I've also seen
cold air "blown thru" the carb. This not only cools the turbo's charge of air, it also can be used to reduce turbo lag to almost -0-. Pretty neat!
By changing the way your sytem compresses air, you can produce a cool charge in the first place while actually INCREASING flow as opposed to decreasing it with an IC.
As for your turbo being so far away from the intake, I wouldn't really worry about that either, as long as you go horizontal & down with the intake, you should be fine. Did you know that the elbow at our cars turbos outlet reduces flow by 10% alone? Buick did say the path between the carb and intake need to be as short as possible but that doesnt necessarily hold true today. Have you considered building equal length tube style of intake? Not only would it look wild, it could be very effective.
I have many, many ideas I plan on implamenting on my T in the future. Gotta get everything up to snuff first tho. Your project sounds pretty fun. I thought of throwing one of my spare t3's on a V8 for kicks myself, but I've kinda been eyeballing this Ford
200 ci inline six I have sitting in my '64 Fairlane. It has more bolts per cycl. than most V8's & more crank overlap. Plus the blocks are thick, the cranks are strong & parts are laying all around for just about free. I think I could do the whole project for next to nothing too. Anyway, that's down the road.
FYI, the carb. to go with if your gonna blow thru is the Holley 4776.
They're only around $240 & are already sealed. a man named **** Datsun is actively trying to find the limitations of carb'd BT systems & has reached 30 psi recently on a 30 inch Stude motor with no ill effects & says he plans on going higher. This is the model of carb he is useing & suggests. Pro charger claims that carbs actually cool the carge up to 30% compared to F.I. Just one more reason, besides cost & complication, that I believe carb's are superior to F.I.
As far as draw thru goes I believe a Weber side draft carb. would be optimal. They are infinately adjustable (but costly) & you could mount it directly to the turbo's inlet greatly reducing lag. They would also save a lot of space too.
Ultamately, I believe the best carb'd turbo Buick reciepe would be a twin turbo DT system with two Webers & air amplifiers in front of 'em. Lag would no longer be an issue then all you'd have to work on is removing the heat. It would be a linkage nightmare tho
Ryan McMakin at Lone Star racing is supposedly working on a twin-sequential turbo's Buick V6. I guess that would be the "ULTAMATE" carb'd Buick V6
