Oxygen injection?
All power adders, turbocharging,nitrous ,nitro etc.,all have the same end effect. To get a larger combustible mixture into the cylinder.
Turbo charging [supercharging] crams a larger amount of A/F mixture into the cylinder without changing the A/F ratio.
Nitrous oxide [NO2] on the other hand alters the ratio of oxygen ,to other gases, in the gaseouse [air] part of the A/F mixture. This is the reason that more fuel has to be added to maintain the oxygen/ fuel ratio.
If we can add oxygen to the mixture in the form of NO2 why not in the form of straight oxygen ? If the proportion of oxygen used is the same as that in the nitrous would it have the same effect? I am relying on my school chemistry/physics for all of this , which was a long time ago ,so I am open to correction any time.
![Stick Out Tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I believe that any gas going from a high pressure state to a low pressure state has a cooling effect. So this would be applicable to both nitrous and straight oxygen. I understand that the nitrous, in the bottle, is in a liquid form so there is an added cooling effect from the change of state from liquid to gas ,which would not be available in the case of the oxygen. Even I think that carrying a liquid oxygen supply in your car may be a little extreme! I cannot see that metering the oxygen into the system would be anymore difficult than metering the nitrous. We all know what happens when you get it wrong.
Now that we are injecting oxygen into the system do we need air? In theory we could now do away with the carburetor all together. Sounds far fetched? I hear that the latest BMW engine no longer relies on a throttle plate for engine control. It is controlled solely on valve timing and valve opening, effectively doing away with the carburetor. I believe it is their intention to put this engine into production. With such an engine it would only be necessary to block off the “air pipe” and inject the oxygen. No more air filters. no more intake restrictions.
I have never heard of anybody trying straight oxygen injection, and I am sure there must be a very good scientific reason for not doing it???
Am I going to try this? No sirree Billy Bob. I have enough trouble just trying to keep my Buick road worthy without stretching the frontiers of science. However I would like to see a couple of SBCs on the sacrificial dyno in the interests of science. I believe that the people at CAR CRAFT have a motto of “squeeze until it bursts”. Maybe someone from there may like to try it and give us some entertaining reading.
Now where did I put those funny cigarettes?
![Roll Eyes :rolleyes: :rolleyes:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
