need scavange pump
They have a pump w/o the by-pass system for scavanging. I believe STS uses that same pump for their remote turbo systems. PM97011 is the P/N @ pre-luber.com
Hope this helps you.
here is the pump i run on my GSXR600 Turbo, this same pump will work and scavenge a twin turbo setup. I have tryed alot of different pumps over the years and over time they would all leak. i found the exa pump and havent had a problem since. yes its pricey but i wish i would have goten it the first time
Exa-Pump®
Hoping to get one slightly used if possible. But if I have to give 300 for a used one I'll add a little more to it and get a new one with a warranty. Still looking though. Thanks for the leads.
