Nascar83Fan
Today i got a nice surprise waiting for me as i came out of walmart walking back to the car ( which is just a couple miles from where i stay ).
Had noticed some fluid under the car affer i had put the stuff i bought in the car and had put the cart in one of the cart returns.
So i put her in neutral with the engine off and pushed her back a spot as there wasnt anyone parked behind me to see if it came from her or a previous car that had parked there before i got there. Anyways had noticed it was transmission fluid, so i fired her up and looked under to see if it was from her or not. Sure enough i had a slow leak of tranny fluid. It was slow steady drips, but not gushing out.
So got her back home, parked her and after i got the stuff i bought inside, took some paper towel back outside with me to try to find where the leak was coming from exactly. Had ruled out it wasnt the easy rubber hose that joins the 2 hard lines. It wasn't leaking from there so i kept feeling around and looking. Once i noticed it was dripping tranny fluid near the oil pan, i started looking through the digital service manual on my tablet, finding the diagram for the way the oil cooler lines run and figured out the leak is coming from a hard line that runs from the oil cooler between the frame and engine before it meets up to the hard lines coming off the tranny.
It won't drip tranny fluid unless i attempt or start the car, so it's either the return line from the oil cooler or the sending line to the oil cooler that has a hole or crack in it somewhere. No other tranny fluid leaks in any other part of the lines but between where i noticed which was under the engine behind the crank pulley where the lines run and frame meet.
It's a stock oil cooler and stock radiator, with original cooling lines none of which have any rust. Also is the factory 200-4r she came with.
What is the best way to replace the lines coming off the cooler that eventually meet up to the hard lines coming off the tranny?
What am i looking at ball park in
spending to buy the stuff to fix it?
What should i be buying and who should i get it from to fix this?
Could i re-route part of the lines by chopping alittle off before it routes under the engine where it still is good and running something to meet up with the hard lines coming off the tranny?
If splicing off of the hard lines is possible to fix the problem, what will i need to cut the hard lines to do so? Want to do it right, not half rear end it.
I've read through tons of threads to see if anyone had this happen but all i could find was about the rubber hard line joiner issue. So that's why i started a new thread here.
Appreciate whatever info that comes my way.
I hadnt drove her 2 days prior to this and then all of a sudden got nailed with this issue. Had no leaks of any sort before today, must of happened once i had got parked at walmart because at the bookstore i stopped at before heading to walmart there was no issues.
I didn't lose more than 1/2 to a quart of tranny fluid, but want to fix this before it could turn into alot worse.
Which is why i haven't moved her since i parked her. Outside of this, she was running great so once this is taken care of there won't be anything else needed to be able to drive her around.
Thanks.
P.S. Sorry for the long post, didnt want to leave any details out so i could get proper feedback back to resolve this.
Thanks.
