SignUp Now!All I was saying is when it gets up to 23-24psi it gets up to 10-15 degrees of knock unless I'm over looking something. But thanks for your time and everyone else that added to this.
Ok dude have it your way. The parameters on the chip are set up to insure that your injectors deliver enough fuel @ the rated 20psi at a predetermined duty cycle. You can offset that buy raising the boost and / or the fuel pressure. Besides I think most TT chips are adjustable. Do you know how many people on this board are running 24,25,30 psi on a 20psi chip? Countless, but have it your way. I'm trying to tell you the most cost effective way to get you to where you want to be, but you can only lead a horse to water so I'm out. I'm sure you'll make it either way but the difference will be 0 dollars and a couple thou more. Good Luck!!
