need some hotair recommendations
87 boosted
Ok guys i got a pretty much stock 1985 gn. Im not new to cars or turbos just new to buick turbo cars. I have read alot of good infomation on this website you guys know ur stuff. Thats why im asking this because, these cars are so sensitive. Im looking to get close or into the 12's with this cars for now. So what do yall recommend i do to accoplish this. Also i drive this car daily so need to keep it dependable. Like i said it is pretty much stock. any information will be appriciated. Thanks
well, first off a spring cleaning.
The Grand National / T-Type / Turbo Regal Buick Spring Cleaning Guide
then
scan tool (powerlogger)
fuel pump hotwired (fullthrottle.com)
adjustable wastegate
adjustable regulator (fullthrottle.com)
Turbo Ta-33 (precision turbo)
alky injection (http://alkycontrol.com/)
60 lb injectors (fullthrottlespeed.com)
ported TB
3 ich downpipe (GBodyParts.com Online)
cat back exhaust (TR Custom Parts 84-87 Turbo Regals, Olds G-Body Cars, S-10 Blazers/Pickups)
after market headers if you can find them (poston or atr)
Up-Pipe same thing if you can find it (postons or atr)
87 ecm conversion
turbo tweak chip with WB correction
lc-1
good trans and a good torque converter
that should get you there ;)
And from what I understand it was only about 340cfm so the TA33 will help. It helped my old 85 tremendously although I went with BlueTops (36#) instead of the 60's. A good torgue converter and exhaust will wake it up too. :)
then
ported TB
87 ecm conversion
lc-1
X2... that covers it pretty good!!
Thanks guys the car has an adjustable wastegate already so my next step needs to be ecm swap, downpipe and exhaust, fuel pump, injectors, Right?
