- May 24, 2001
Need:
Plug/pushpin that holds the kick panel/ECM cover to the car. It is on the outside of the kick panel where you rest your feet.
In the glove box on the top of the door there are two rubber nipples on each side to keep it from rattling. Need 1 of the nipples
Under the hood where the original air cleaner and snorkel are there is a metal clip that goes around the radiator support. There is a black clip/push in button that goes through the clip and radiator support holding it on. Need 1
