gn86randy
No can......can
- Aug 1, 2004
Here is a little history of this car I picked up, its an 87GN and it threw a Rod suspect that they were not properly torgue'd when the engine was recently rebuilt, Anyhow here is my perdicament.....the car has a PTE-51 with the Poston 212-204 cam 110....it also had a set of hyperuretic .030 Poston Piston's and ported Steel Heads with larger valves...I have a 62 turbo and 50lb injectors and an 8 pos Max Effort Chip just sitting in a Box was wondering with which turbo I should go with the 51 or the 62 with the 50lb injectors......Well that is my situation, some of you may already know this cars History I got it from ARMYMP over here in Hawaii.....so any and all insight is welcome.....I also replaced the hyperuretic pistons with a set of .030 Forged should be able to hold the boost better than the hyperuretic ones or so I've been told.......and my last concern is that I picked up a set of high rev lifters from poston's as well will they work with the old cam.....cam is still good......
