BRAD_PADGETT
- Jan 22, 2004
I ohm tested my coil pak which failed and replaced it. The ohm test on my spark plug wires was a failure as well. All wires should have tested within ten percent of each other. My wires were all over the place which means they have to go. What kind of wires should I get? Do the 87 kits fit the hot air? I am running a GM coil pak and coil module. Thanks- Brad
