CombatComProg
- Aug 28, 2004
I bought a rebuilt steering column for my 87 T and it was shipped "collapsed" by the vendor. I noticed the end shaft was about 1.5"-2" shorter than the original column that I pulled out of my car, and this is because the new one was shipped collapsed as explained by the vendor. I took my steering wheel off of my old column and put it on the new column. I then tried to "uncollapse" my new column via the method instructed to me by the vendor, which was to put a screwdriver through the hole at the very end shaft of the column and pull on the screwdriver to pull the shaft all the way to its correct length so that it may reach the steering shaft in the engine bay. I tried this method with a friend and I standing on the steering wheel while I put a thick screwdriver through the end shaft and pulled up - no results. I mounted the steering column fully in the car and tried the screwdriver method -no results. The only thing I could do to get a little budge was to stand on the steering wheel and lean all my weight onto the part that mounts onto the firewall. That cause a few millimeters of the end shaft to extend, but it immediately contracted to its original length as soon as I took my weight off of it. What do I do? Any idea as to what machine or tool I can use to pull this shaft to its correct length, or is there some button I'm forgetting to push -lol. I need help soon! Thanks!
