Need to Rebuild a Trash Rebuild: 87 GN Help Needed...
Joe Rainville
Hi Guys,
I accidentally bought a project car that was supposed to be a nice condition original, 68,000 mile car. It had no codes or issues via the scanmaster gauge except a lousy idle and hunting IAC. While chasing a rough idle, turns out the timing chain had jumped because someone replaced the cam and lifters, but when they did the chain, they only replaced the top gear. So, the chain stretched and jumped. While looking to repair that, I pulled the rear main bearing to replace the seal (since I pulled the pan) and found the bearing was down to the copper.
What I though was an original engine had a "260" grind cam and 0.030" over Summit Racing pistons on the worst quality rebuild I have every, every seen. Even the hone job was trash. So here we are. My crank is scored, bores are questionable. I already had the intake corrosion repaired around the coolant ports, new Delphi fuel injectors, (new 20% over stock fuel pump), new stock replacement ignition system, (except the cam sensor), most all new sensors on the intake such as temp, TPS, IAC etc. I have a Cordone rebuild MAF and a new factory turbo. Stock intercooler stays but the terrible hack 3" exhaust will be updated. Aside from the overbore and cam, the motor looked 'stock'. Here is what I have in mind for my rebuild:
Regrind or new crank. Looking at stroker vs. std stroke kits. Have the block evaluated to see if the 0.030" overbore is useable or if I need to go 0.040" to clean up the mess. Pistons are a question as T/A sells 8:1 cast, while GN1 sells more expensive forged. I am planning a mild roller cam and roller lifters. Thinking of TA Steet Intimidator aluminum heads and increasing the head bolt count from 8 to 14. Probably going to add billet main caps for the center two, plus line bore, decking and whatever else my block needs. I want to keep the stock intake and valve covers for factory appearance. A full SS exhaust with street headers and a 3" downpipe with the built in wastegate will replace the factory cast elbow.
End goal is a smooth idle, good drivability and of course more power over the stock 247/355. HP goal is around 350-400 ish hp on pump gas. And ya, going to get the 200R rebuilt while I am at it...
Questions: Does this round reasonable? What about the factory computer? Are folks still burning chips?
Thanks,
-Joe
87 GN, chasing demons out of it since 2016.
My stock 30k engine went 11.3 with only changed valve springs and external mods/fuel/alky control/exhaust/chip/drag radials/trans and converter. So a goal of 400hp is very easy on a fresh rotating assembly, roller cam and turbo with good exhaust, fuel mods, alky or E85, good tune with TT chip. Now to build creep, you can do ported iron head which is frankly silly not to while you're at this point. Billet caps adds more to the build creep but again if you're there and adding new rotating assembly then it does make sense. Do not skimp on fuel and injectors. Go for a good downpipe and full 3" exhaust. Make sure your stock headers are in good shape, repair or go new but that's a big expense. Now do not forget to get an O2 wideband and a Powerlogger for the stock ecm. No sense at all spending thousands on an engine and not knowing wtf is going on with the tune at WOT. That's my take. Sure others will add or subtract. PS, use machine shop familiar with Turbo Buicks and local if you can.
chuck he is new to the TR and dose not know that's not possible. Really why is the heads made with 14 bolt we know why but it just seems reasonable to tap the block and finish what the factory didn't do.
Pronto is correct find a TR builder, Where are you located? you seem to be looking at TA performance parts, so if your in the AZ area code you will find a few builders up to the task.
I fill the two best 200r trans people are east of the Mississippi.
Hi Guys,
Thanks,
-Joe
If you are going for 400 hp you do not need to go with aluminum heads to get there. On a stock block, you cannot use 14 bolt head studs its an 8 bolt deal and that is all you got. Only on Stage1 or Stage2 blocks can you go that route. A TA block will of course do it as well but that is $8000 just for the block.
You CAN make 400 hp on stock crank, rods using a set of forged pistons to fit the bore.
For the cost involved and what you are going for I would suggest the following.
If you can get away with using a .030 over bore piston, use the block you have.
If not then find a good 109 block and build on it.
109 block
Forged rods
Forged pistons go to a 9 to 1 CR.
Port and polished iron heads will work just fine on your combo ($2300 vs $4000)
Hyd roller cam
Roller rockers and that will require a set of aftermarket valve covers to clear.
Rebuild timing cover with a high volume pump
Deep sump oil pan
Clean and flow test injectors
Alkycontrol kit
You can get a chip from Turbotweak for the new combo using the stock ECM and be good.
Turbo. You can get away with a stock turbo to make 400 hp or there are other options that will work just fine. A 58/58 is more than enough.
I would recommend getting a converter specd out to match your combo. It will help with spool up and handle the power. Your stock trans may not hold up to the additional torque but we will leave that for another discussion.
Ask away if you have more questions.
Gentleman,
This is my first GN, but I have always been a gearhead. But I do not know all subtleties of the GN, but being a former fuel injection engineer for Delphi early in my career has been helpful with straightening out the fuel and ignition system issues I had when I first bought this thing. Like I said, it wasn't "supposed" to be a project car and the motor was claimed to be a stock original, not a 0.030" over POS rebuild. I am quite sure it was put back together with junk, scored crank, as some of scored journals have unscored bearings. Finding the original lower timing gear on the crank was pathetic. The cross hatch from honing is more like 5 degrees, not 45 deg. Whoever "rebuilt" this engine with Summit parts should have his tools confiscated.
I am located in Fort Worth, TX.
I not sure my block is useable, as the lower end of one of the bores looks thin. I am also not sure the scored crank is savable without breaking out the micrometers. But, I am budgeting for a new forged crank in case mine is hosed. I have been looking at GN1's rotating assemblies, but they seem aimed at race cars.
I was assuming there was enough meat on the top deck of the block for extra head bolts, but apparently this is incorrect by what you guys are saying. The TA SI aluminum heads are pretty reasonable, starting at $1,370 for a bare set. Valve size increased to 1.94/1.6 from 1.71/1.5 and the flow is improved, especially on the intake.
If my block is hosed, how hard is it to find 109 blocks? The TA aluminum block is sweet, but serious overkill for a street cruiser at moderate power levels.
As for pistons, I was going to stay with 8:1 compression, but the engine builder I am talking with (race motor builder in NY) thought that was low, and I should consider going to 8.5 or 9:1. Forged vs. Cast? Always thought forged are stronger and light, but cast are usually more durable. GN1 offers forged, and TA offers cast, or custom order pistons it seems.
I am keeping the stock turbo because I just bought the darn thing and car hasn't left the garage with it on yet.
I already installed new AC Delco Injectors that I now have to dig up the spec on, but they were rated to flow more than stock, just not sure how much more.
Fuel pump was rated for 20% over stock flow also, but when the original died, I wasn't planning to modify the car
I want to do a hydraulic roller, haven't spec'd the profile yet. I want a smooth idle though, as running the AC in TX summers is a requirement.
I have a new timing cover, oil pump head, and gears.
Reggie,
I will check out "Turbotweek" for a chip, as the $2,500 standalone computer seems a bit much for street cruiser.
How bad are the stock rods as far as how much HP can they handle? I should probably build a bottom end that can handle a larger turbo in the future in case I get frisky later on.
I hope I can keep the stock valve covers, but roller rockers are obviously desirable. If not, I guess I will try to find stock looking ones.
And once I get the engine rebuild under way, the Turbo 200 will get sent out for the strength updates.
Thanks for all the feedback guys, and sorry for some of the "nube" questions. Despite being 55, this is my first time rebuilding a GN.
-Joe Rainville,
Fort Worth, TX
Your in Texes Zimmerman and TA are in Phoenix both build good Buick stuff GN1 has good stuff I will always be a repeat customer to Full Throttle.
I think that have the largest selection of roller cams. about to have a good pissing match to what cam you should use. I do like there rotating ass as will but GN1 .RJC has a spacer for the OE valve cover to run roller rockers. Ta will send you all the things you need for there heads. Aluminum heads you should be 9.5 - 10:1 9;1 Min.
Stock rods have not been found as a week point, But if you need crank and pistons might put new rods between them
Go with the higher compression. You will have more power for driving around not in boost and boost will come on faster. If you need a crank then go with a stroker kit for the same reasons. New cranks will be internal balanced so you'll need an internal balanced flywheel. If your crank is ok, no need. No need for al heads if you don't plan hard core dragging. BTW, ported irons have been all the way to 8s so they should cover your build no problem. As far as the injectors, the stockers were barely good enough for stock engines. With minor mods they don't flow enough. 60s (more than double the stockers) from TT with his TT chip and alky will be plenty fine for good potent street car with 10s potential. With the roller cam you can go 206/206 or 212/212. Either will have a nice idle and give you all the power potential you'll need. You'll need a better fuel pump. Best to just go with a Racetronix sending unit with the pump and hot wire. They flow real well compared to the stock sending unit plus the hot wire makes sure you'll get full 12v at the pump. Roller rockers will need a tall cover or a spacer for the stock v/c. The spacer's can be tricky to seal though. As far as temps in TX, the cam is not the issue, the cooling system. If you still have the original rad, it's gunk by now. Go aluminum with dual fans. Throw that rebuild MAF in the trash and get an LS MAF and translator. Rebuilds are garbage. The stock intercooler will be a huge choke point. If you don't replace it with a larger slic or front mount you might as well just build the engine to stock specs and putt around with the Hondas. The stock turbo will also be a choke point. The new billet small turbos spool lighting fast and flow a lot more air.
This lil' bugger does pretty well for what's in it. 532 at the tires, that's well over 600 flywheel. 23psi.
stock crank / rods / balancer / flexplate balanced with wiseco pistons 8.8:! CR
stock 8445 iron heads with bowls opened up (econo-port), stainless valves, harland sharp rockers, 1201x springs
210/215 full throttle cam, johnson lifters. stock intake ported just a bit and welded up the EGR.
stock main caps, ARP studs throughout. TA front cover and rollmaster red label timing set. Fully documented clearances throughout, a detailed build sheet is a must.
6266 turbo, precision intercooler, and ECUGN controlling it. 120lb injectors, E85, hellcat fuel pump.
pretty simple and budget minded. Has over 5000 miles on it now, just went for a 300 mile trip to Osh Kosh yesterday.
Nice straight forward build. Being able to run E85 is a big help. No alky kit needed, just bigger pump and injectors.
Since you are local this is the place several Buick guys use. Get in line now as last time I went by he was about six months behind on taking in more work according to him.
Where did your car come from? I'm guessing you will be doing the work? New parts can be had. Used stuff is more of an issue. Yards around here crush pretty regularly so if you don't make the rounds and get the things out it goes on to china to become washing machines and refrigerators.
I'm over to the east in Arlington.
You could buy a used, stock, Buick built engine with 150K on it, change the timing gear set (if not done already), pop on an alky. kit or build one easy enough, small turbo and 3K stall converter (rebuild the tranny too) and make over 400 RWHP for many years to come at 24 psi. usual bolt ons.
It's been done since the 1990's.
Just my .02, and a couple K for the tranny work. :)
Then again you would need an honest seller to sell a stock Buick engine, after the first experience I would understand the reluctance to do it this way.
