neutral drop????
badboy86gn2
"lord be with me"
hey guys
when i get on the car and then come to a stop sometimes it will like go into neutral then i give some gas and then it gose into gear
have full fluid
shifts fine
is my tranny taking a dump???
Johnny
let me know what to check for
cool ill look into that anyone else have more input this has to happend to someone
Johnny
On most trannies (early 700s and TH-350s, not too sure about the 200R4) there should be some plugs along the passenger side. Can't find a picture to save my life, someone chime in here. Unless you can get someone to tell you what plugs and what pressures you're getting, you'll probably need a 200R4 book anyways.
plug
On the 200 there ia a 1/8 in. pipe plug (takes a 7/16 wrench) half way up on the drivers side just above the shifter linkage. You will need a 300 psi gage.
