- May 28, 2001
Spent the day trying to get the neutral micro in the B&M shifter to work. Have the service manual and tried a wire or 2 and no luck.
Can't use the stock linkage as it's a T-400. [Had it modded and it worked for a while.. now can't get it adjusted so trans gets all 3 gears]
. It's off the car and in the junk pile and I'm too stupid to figger it out!!
Looking at the wiring, I see the infamous PURPLE wire to the starter sol. from the ign sw on the column. Problem is: it's a 12 ga., and obviously intended to carry a higher load than the puny little micro can. Guess a relay is required?? Ideas??
back to scratchin my a$$!!
PS: FWIW, The theft det. system used a relay in the purple wire, cept it was purple w/ a wht stripe..
