Neutrals out when hot.
Steve V
Steve V's Automotive 757 560 2782
Got an 85 700r4 that neutrals out when hot works fine when cold. I am thinking seal are getting brittle? I have it partailly toredown and no issues so far. Pump looks good,no debris in pan. Maybe a problem in the input housing. Any ideas?
Did some more picking tonite. All clutches and plates looked good. Looked at all the valves in the VB and they are free. Pump looked good,PR valve had 1 land ground off for "full time lube",1 only do 2 flats but that should not cause this. I air checked all the drums..ok....I need to pull out all the pistons in the input drum and feel the seals.
