New 30-spline Moser Axles, New Detroit Trutrac, New Alum Cover(girdle) Two 8.5 Rears, 3.42 & 3.73
V6UnderPressure
The Artist FKA Scott4DMny
Everything has been sold except for the GN Rear. 1 out of 87 Grand National with 101k miles on it. Has 3.42 posi. The differential, hardware and backing plates have been removed. However, I have everything except the axles, drums, rear cover and one of the upper bolts(had to cut it off). It has urethane upper bushings installed. 700 picked up. All that is left is the Grand National 3.42 rear end. I will include original shims, so if you wanted to reinstall the carrier, the backlash and preload should be fine. Here are the photos. I will also include the original driveshaft and Brand New Timken axle bearings/seals for a limited time if you purchase this rear. This will make your upgrade from 7.5 much easier.
I am local PM me a price picked uo for the otber posi and axles
All parts sold and the 19k cutlass rear is spoken for. All that is left is gn rear with 3.42 posi
