new 5" downpipe, ported wastegate, boost spike. grrr. angry
I'm just curious... What type of combo are u running that u need a 5in DP??? And if u haven't already u should wrap that silver stuff that keeps surfaces cool around your fuel lines that are by that humungous DP
i know, the dp is overkill overkill, but it was cheaper than a thdp, and i'm an addict- so i was hoping to grow my habit right into it.
i've had some local help, but....
i was sure since in would spike over 25lbs. and seemed to hold 20lbs good with the vac. line off- that it was the actuator. but i put the stock actuator (rigged) but back on, with the rjc valve, same behavior - spikes to 19 settles to 14.
i know the erg was leaking from the stem when i did a pressure test. i guess i'll work with that and check for exhaust leaks one more time:confused:
trying to set the rjc low and use the rod, didn't work.
thanks for everybody's help and suggestions, i just wish this was an hourly job.
5"
buddy your damn down pipe is bigger then my house sewer line ::biggrin:
