New 6265B DBB turbo arrives tomorrow and I need...
Reply
you have been warn keep your personal thoughts to yourself i would hate to see chicken get into some trouble because of you.:D
Children should be seen not heard , Do not interfere when us adults are having a meaningful intellectual exchange of ideas. Anymore of this & you should be issued another citation by the moderator.
So the good news is I was able to re-torque my head stud nuts and can return SPOOLFOOL2's TQ wrench tomorrow. On the passenger side, the bottom 2 rear most nuts were definitely a little loose, so I'm glad I took the time to do this.
The bad new is....one of those little plastic buttons that hold the rocker arms in place on the rocker shaft, broke. As I lifted the rocker shaft out, the little button fell apart.
Papa Lou...have any spare's?
SPOOLFOOL2...I'll take you up on the offer for the paint. I'll pick it up tomorrow when I drop off the TQ wrench.
Thanks for the hook up on the rocker arm button's, Lou. I drove it in using an old small block fuel pump push rod I had laying around. Went right in without an issue.
Putting it back together a bit at a time...passenger side header went in tonight. Tomorrow I'll do the driver side header.
Still need ot order that 4" to 3" reducer to go between the MAF pipe and turbo, but I'm in no rush for now.
Gonna fix the torn exhaust hangers at the cat and in front of the axle, too.
