Toby_Goodmk
Test Fit officianto
- Dec 9, 2011
I went to a Jones racing pump for my hydroboost system. I didnt need to do to a mis-diagnosis of the pump being bad. Well, I cannot take it back, so I ordered a new one, regardless if it was truly bad or not. So, this is what I have for sale. Help me pay for a new set of slicks for 2016!!!
1. New Cardopne pump (rebuilt one). This one looks really good, even the inlet if not all banged up like they always are. Ill even send you the receipt so you have have the lifetime warranty with it. I have like 90$ in it with a core.
2. Power steering pulley has been blasted and powder coated, it is very nice...now.
3. Both New hydroboost pressure lines, these are AC Delco brand. I have 75$ in both them. I decided to go AN fittings instead, so dont need them. threw away the box like a boob so cannot return them
4. The pre-bent factory hose comes with. It has been T'd at the correct spot, it also has all new correct factory style clamps holding the lines onto the T
5. Pure Choice motor sports 2.2 GPM orifice valve will come with it. I found it very helpful to slow the speed of the fluid from 3.2 to 2.2 to aid in aeration of the fluid in a factory style reservoir. If you have a larger res, like I have now, you can get away without using it. If not, you will want to use it. It also makes your steering very comfortable at high speed since the steering needs more effort due to less flow. Some like it, so prefer easier steering. I cannot use it in my Jones, so you get it as well! I got $30.00 in it.
6. A power steering filter, you need this to keep the nice new pump operating. Got $20 in it too.
$200.00 gets it all. This would make for a NICE out the box conversion for someone going to hydroboost
