Brakes Work
Thank You, "My Brakes now work". It was the accumulator. After knowing that there was a diaphram that hold the charge of nitrogen it gave me the confidence to install. Now I understand that the 300psi nitrogen charge is what pushes the fliuid once the pump fills the accumulator with fluid. So has long has you depressurize the Brake Fluid side of the diapham it is safe to install the new accumulator.
Thanks Again Guys for you help.
