New and Used GN Parts For Sale
Jwest
The following list of parts are from my collection over the past 20 years; I've recently sold my GN and would like to sell these parts. All parts prices do not include shipping, my zip code is 68116 if you wish to estimate the costs for yourself.
Thanks,
James West
Omaha, NE.
Description: *All parts are new GM NOS parts unless described otherwise*
1986 – 1987 GN/T-Type Mass Air Flow Sensor, GM p/n 25007866 $150.00
1987 only Grand National Grille, GM p/n 2552614 $125.00
1986 – 1987 Grand National/T-Type Power Master brake accumulator ball, Delco p/n 18038507 $105.00
1986 – 1987 Grand National/T-Type Power Master brake switch, Delco p/n 18018141 $75.00
1986 – 1987 Grand National/T-Type GM NOS trans. X-member exhaust hanger bracket $80.00
1982 – 1987 Regal/Grand National trunk weather stripping, NOS in the box GM p/n 25558394 $40.00
1984 – 1987 Grand National/T-Type front air dams, GM p/n 25525980(L) 25525981(R) $80.00/pr
1986 – 1987 Grand National/T-Type Crank Sensor & Mount Bracket, GM p/n 12537114 $20.00
1986 – 1987 Grand National/T-Type Crank Position Sensor GM p/n 12537109 $20.00
1982 – 1987 Grand National Left Rear wheel opening molding GM p/n 20498650 $50.00
1986 – 1987 Grand National/T-Type coil pack with gasket GM p/n 12353801 $40.00
1986 – 1987 Grand National/T-Type turbo boost solenoid to turbo vacuum hose p/n 25525576 $8.00
1986 – 1987 Grand National/T-Type PCV Valve AC Delco p/n CV893C, GM p/n 25095468 (2 available) $5.00/ea
1986 – 1987 Grand National/T-Type AC Delco Engine Coolant temp sensor, GM p/n 12146312 $12.00
1986 – 1987 Grand National/T-Type Oxygen Sensors
(1) Denso p/n 234-1001 $22.00
(1) ACDelco p/n AFS-81 25162600 $22.00
(1) ACDelco p/n AFS-20 25162693 $22.00
***Buy all 3*** $60.00
1986 – 1987 Grand National/T-Type AC Delco Fuel Filter p/n GF 652F GM p/n 89058397 $10.00
1986 – 1987 Grand National/T-Type fuel injection rail schrader valve (1), GM p/n 2553266, schrader valve cap, GM p/n 25532662 $10.00/both
1986 – 1987 Grand National/T-Type Fan Relay, GM p/n 10038490 not sure if this p/n is correct $15.00
1986 – 1987 Grand National/T-Type AC Delco Heater / AC Fan Switch, p/n 16032480 $1.50
1986 – 1987 Grand National/T-Type AC Delco MAF to turbo air inlet black anodized hose clamps (pair), GM p/n 25527699 $15.00/pr
1986 - 1987 Buick Grand National 120 Amp alternator rebuild kit which includes;
(1) Bearing, GM p/n 908419 $8.00
(1) Bearing, GM p/n 10474532 $8.00
(1) Brush Holder, GM p/n 1989702 $9.00
(1) Rectifier, GM p/n 10467052 $25.00
(1) Regulator, GM p/n 1116437 $30.00
TOTAL $80.00
1986 – 1987 Buick Grand National/T-Type ECM computer module (remanufactured) with GM CAL Pack, GM p/n 1227148507 $50.00
Garrett Air Research TE-60 Turbocharger with high boost actuator, like new condition with rebuild receipt from Limit Engineering (August 2009) $400.00
One (1) pair of 1986 – 1987 Grand National wheels that have been widened to 8 inches. These Wheels have a 4 inch back spacing and are in mint condition, they have never had tires mounted on them. These wheels are in mint/better than new condition. $300.00 (Sale pending)
1984 – 1987 Grand National/T-Type “BUICK” grille emblem GM p/n 25526879 $10.00
1986 – 1987 Grand National/T-Type hood release cable assembly new in the box from Caspers $20.00
Delphi fuel injector O-ring service package p/n 17113544 $5.00
Federal Mogul front sway bar bushings (2) new in the box $8.00
GASKETS
(1) Differential Cover Gasket $3.00
(2) Upper Intake Manifold Gaskets, GM p/n 24502089 $2.50/ea
(2) Turbocharger Compressor Inlet Bell Gaskets, GM $1.00/ea
(4) T-Body to Upper Intake Manifold Gaskets, GM p/n 25517008 $1.00/ea
(1) Upper Intake Manifold Vacuum Port Gasket $1.00
(5) Turbocharger Oil Drain Flex Tube Gaskets $0.50/ea
(1) FELPRO Exhaust down pipe donut Gasket, p/n ES 72697 $12.00
(1) FELPRO Buick V6 Valve Cover Gaskets (1 pair), p/n C 5056 $10.00
(1) FELPRO Buick V6 Valve Cover Gaskets “Perma-Dry”, p/n 50156T $15.00
***Buy them all*** $30.00
1987 BUICK NEW CAR DEALER LITERATURE
1987 Buick Buyers Guide
1987 Buick “How to Build a Hot Buick”
1987 Buick Exterior Colors and Wheels all for $25.00
USED PARTS
1986 – 1987 Grand National/T-Type “109” V6 engine short block w/60k miles never rebuilt $499.00 **Buyer arranges all shipping***
1986 – 1987 Grand National/T-Type engine crankshaft balancer attachment bolt w/ washer $3.00
1986 – 1987 Grand National/T-Type engine oil filter mount that attaches to front cover $10.00
1986 – 1987 Grand National/T-Type turbo adjustable high boost actuator $35.00
1986 – 1987 Grand National/T-Type turbo exhaust elbow with spring bolts $9.00
1987 Buick Grand National/T-Type engine starter w/ mounting bolts (30k miles when removed) $30.00
1986 – 1987 Grand National/T-Type Throttle Position Sensor (TPS) $15.00
1986 – 1987 Grand National/T-Type Throttle Position Sensor (TPS) mounting screws $4.00
1986 – 1987 Grand National/T-Type Throttle Body with IAC motor and vacuum block, no linkage $35.00
1986 – 1987 Grand National/T-Type Throttle Body blade $.50
1986 – 1987 Grand National/T-Type vacuum hard pipe(s) to fuel pressure regulator $35.00
1986 – 1987 Grand National/T-Type heater hard pipe with intake manifold attachment fitting and heater core water vacuum shut-off valve $60.00
1986 – 1987 Grand National/T-Type custom made stainless steel EGR valve block off plate with bolt and hi-temp gasket $5.00
1986 – 1987 Grand National/T-Type front and rear brake lines that go between the Power Master unit master cylinder and the brake system proportioning valve $40.00
1986 – 1987 Grand National/T-Type brake system brass proportioning valve in GM box $40.00
1986 – 1987 Grand National/T-Type fuel pump hanger/sending unit for a car with analog dash $80.00
Aluminum rear brake drums, good condition. $25.00/pair
1986 – 1987 Grand National/T-Type ATR rear differential pinion snubber $4.00
ATR fuel rail drain hose kit with fuel pump hot wire jumper wire $5.00
Fuel pressure testing gauge with 12 inch hose, schrader valve fitting and 0 to 100 psi gauge $20.00
Sutton Engineering Co. Variable Pressure On-car Fuel Injector Cleaning Kit, complete with all the fittings, pressure gauge and instructions $30.00
OTC Engine Monitor 85, model 3485 with data port cable and operating instructions $20.00
One (1) Jay Carter 92 octane street chip for 009 injectors, this chip has the anti-theft feature $15.00
One (1) ECM chip carrier $2.00
I'll take these:1984 – 1987 Grand National/T-Type “BUICK” grille emblem GM p/n 25526879 $10.00
Aluminum rear brake drums, good condition. $25.00/pair 1986
I'll take the following:
ATR rear pinion snubber $4.00
all 5 turbo oil drain flex tube gaskets $5.00
Fuel railschrader valve and cap $10.00
NOS trunk weather stripping p/n 25558394 $40.00
Thanks. Paypal? and shipping to 33408
Thanks kindly :cool:
I'll take the
1986 – 1987 Grand National/T-Type coil pack with gasket GM p/n 12353801 $40.00 IF you have the original box.
Total, shipped to NJ 07840?
Thanks!
I would like; the engine crankshaft balancer attachment bolt w/ washer $3.00
total paypal? or POMO shipped to 18452 please Thanks Tom
2nd on the trunk
If not sold ill take the nos trunk seal.
ALSO 2ND ON THE AIR DAMS THANKS
i would like to be first for the 87 only gn grille 2552614 125.00 this is the black one right? paypal info and total with shipping to 45801
If not sold I'll take these items.....
New Acc brake ball
Trans X-member exhaust hanger
Crank sensor
Left rear opening molding
Coolant sesor
Aluminum rear drums
Tks, Scott
Head lights
My 87 GN has 3 of the original head lights. Would you have any and if so I'm looking for the passengers outside , low beam, lamp?
if still avail, interested in these:
GASKETS
and need more info on this:
thanks!
If available I'll take 1986 – 1987 Grand National/T-Type turbo exhaust elbow with spring bolts $9.00 & 1986 – 1987 Grand National/T-Type turbo boost solenoid to turbo vacuum hose p/n 25525576 $8.00 Shipped to 43452 Thanks
Second in line for "1986 – 1987 Grand National/T-Type coil pack with gasket GM p/n 12353801 $40.00", box doesn't matter.
Mel
Pair of widened 86-87 grand national wheels
Would like to be put in line for these if still available.Do you have any pics?
Interested in these btw
I'll take the shortblock to CT if you can put it on a pallet. I'll arrange for pickup
