- May 23, 2001
A good laid back fun event. We had great weather. I ran my new best time & dad went into the 9s. I believe Razor went a new MPH best. Great event looking forward to next year.
Details of the run:
60' = 1.641
1/8 = 7.27
MPH = 93.09
1/4 = 11.390
MPH = 117.4
Rob Hinson, TTA# 1437
EMPTY WEIGHT: Stock
BLOCK: Stock
HEADS: Stock
CAM: Stock
TRANSMISSION: Rebuilt by Lonnie Dyers (awesome tranny)
TORQUE CONVERTER: 9x11 3200-3400 stall
DIFFERENTIAL: Stock
INTERCOOLER: Stock w/ Dutt. Neck
THROTTLE BODY: 62mm
RJC POWER PLATE: yes
INJECTORS: 009s
THERMOSTAT: 160º
TURBOCHARGER: TE62
VALVE SPRINGS: Comp Cam 911
MAF: Stock
DOWN PIPE: TH 3"
EXHAUST: ATR 3"
FUEL PUMP: Walbro 307
FUEL PRESSURE REGULATOR: Adjustable
FUEL PRESSURE: 43
ALCHOHOL INJECTION: Alky Control Progressive
PROPAIN INJECTION: No
NITROUS: No
AIR FILTER AND AIR INTAKE: K&N w/4" inlet mounted outside the engine bay.
TIRE DESIGN, SIZE & AIR PRESSURE: MT ET Streets 28*11.5-16
AIR BAG(s): No
SUSPENSION: Stock
SCAN TOOL: Scanmaster
FUEL: 93
CHIP: Reds 107
CHIP TIMING: ??
KNOCK RETARD: 0.00
OXYGEN SENSOR VOLTAGE: ??
EXHAUST GAS TEMPERATURE: 1600.2'
TRACK ELEVATION: ???
TEMPERATURE: 60'
PEAK BOOST: 27 PSI
BOOST AT LAUNCH: 5 PSI
MILES ON THE CAR/ENGINE: 81k
-Rob Hinson
Details of the run:
60' = 1.641
1/8 = 7.27
MPH = 93.09
1/4 = 11.390
MPH = 117.4
EMPTY WEIGHT: Stock
BLOCK: Stock
HEADS: Stock
CAM: Stock
DIFFERENTIAL: Stock
THROTTLE BODY: 62mm
INJECTORS: 009s
THERMOSTAT: 160º
TURBOCHARGER: TE62
MAF: Stock
DOWN PIPE: TH 3"
EXHAUST: ATR 3"
FUEL PRESSURE: 43
NITROUS: No
AIR BAG(s): No
SUSPENSION: Stock
FUEL: 93
CHIP: Reds 107
CHIP TIMING: ??
KNOCK RETARD: 0.00
TEMPERATURE: 60'
PEAK BOOST: 27 PSI
-Rob Hinson
