New best for Carlos Rosas
87buickracer
Ran at the bop yesterday in gainesville florida..with engine and trans built by me...This run was against don cruz..I thought for sure I was history as I was doing the driving in carlos's car..
rt-.407
60ft -2.390
330ft-5.879
1/8- 8.485
mph-95.20
1000ft- 10.718
1/4 -12.610
mph- 118.98 @26psi boost(no traction thru 60 ft)
I was peddling the car thru the 60ft because tires broke loose on launch(Need to change converter to 3200-3400 stall to build boost on line)..I'm sure this car will run a low 11 or hi 10 with more traction and a solid launch at the same boost level...car ran smooth and effortless down the track..at 3500lb ,mph is roughly a 11.5 et..
On that run don broke his crank sensor and had to abort the run,lucky for me..:smile:
Here is carlos's 11 second combo
te 62 turbo
3" thdp w/dump
2 1/2" dual exhaust with flow master mufflers
9/11 3000 stall converter
60lb injectors
210 billet roller cam
red's xp fuel pump
ported heads
autolite 23s gapped at .32
msd 8mm wires
felpro 9441pt head gaskets
razor alky kit(The best!!)
stock tb/pl/intake
ebay fmic
lt1 maf and translator
full throttle extender chip for alcohol injection
original atr headers
t+d 1.55 roller rockers
3.73 gears
275/60/15 drag radials(bald..lol)
Tuned with otc4000e,and old turbo link...
Man youd be in the mid almost low 11s if you could get the car to 60ft, great MPH.
car needs a line lock for burn out box and a 3200- 3400 stall converter for a 7 to 10 psi launch instead of zero and more traction(lift bars maybe)..and a new set of drag radials;)....It felt like it had plenty power left in it..with razors kit I'm sure we could make more boost if needed,but for know I think we have enough..just need to work on those other issues..
(On that run don broke his crank sensor and had to abort the run,lucky for me..)
I was told that it was Tony gomes instead of don cruz,not sure but here is a picture of car with cal hartline under hood...maybe someone can chime in who knows this car..
