new best this weekend
ITSNOTAGN
Shadow Master
went to the track on friday night, cars not completely up to snuff yet, badly cracked header, stock fuel pump, but everything else is pretty good now. oh yeah, except the 9 year old radial tas it has on it, and the wheelhop. but anyway, got there and got 5 gallons of plain alcohol, filled er up, and ran solid low 13's all night. ended up with about 23psi, 23/19 timing, im pretty sure anyway, and my SMC single nozzle kit maxed out, coming on at 11psi. but heres the best run i had
60' 2.13
330' 5.7
660' 8.64
mph 84.22
1320' 13.24
mph 105.14
only picked up 21 in the last 1/8th on that one. best MPH was a bit over 106 though. need to get that header fixed really bad, and im spinning through 1st completely and a little in 2nd. i think i have the mph for 12's, but after 3 of those runs my trannys stating to show her age. something very strange is going on with my o2 sensor too. it progressively drops down to 0 on a WOT run, but works fine all other times. and its brand new with excellent x/counts. i dunno. but a stupid neon got down to a 13.09 though, bastards, im gonna catch him yet. So razor, what do you think? i think im gonna go to a 2nd nozzle pretty soon, just on a single m10 right now.
BUY SLICKS.
Those where easy 12 sec. passes with traction...Oh and I almost forgot you're wheelhop, fix that to.
ITSNOT:
All TR SMC kits ship with an M15 nozzle......are you sure it's a 10?
My o2 did the same thing at wot 0mv at wot it happened to be a bad o2 sensor worked fine during cruise good cross counts but at wot 0mv heres how u find out if it is your o2 at wot make sure your 02 isn't showing crosscounts at wot a proper working 02 shows mv at wot but no crosscounts mine would cross count at wot with 0mv took me a month to figure it out i though i was running out of fuel and when i my alky came on it would just sputter and backfire car lost big power because of this it was not a delco 02 sensor ,but as soon as i bought the delco sensor purple wire my problem was solved yes u do have mph for 12's i ran a 12.6@106 with a 1.83 60ft.91 octane homemade alky kit
check that, it is an m15, thanks. i think im gonna go to 2 m10s in the future.
i wasnt thinking that my o2 was bad, but hey, new ones suck too! gonna have to change that out soon. gonna try out one of those new lead-proof denso ones.
Dual tens are overkill for your combo - I can drown my car pretty easily. One m15 took me to solid 11.8's with Steve's kit.
Jeremy
