new best
chikn305
Took the car out last night with the new short block the old one broke a main cap. Anyways 1st pass was a 1.39 60 & 6.32 @ 106. I was running 110 & thought I would need the alky but found out I need it or another pump & injectors.
Yeah, I would say you are at the limit there without some more fuel, unless the car weighs less than 3000lbs w/driver. Nice time!
quick times
i ran into a problem with my car..i have 72's with a dual nozzle alky control..i was running out of fuel at 109mph in the 1/8..i now have a double pumper with the second pump coming on at 5lbs of boost..it's has plenty of fuel now...i would go with at least 72's on your car...what boost are you running?
I an running 26psi. I was thinking about going with the new 79lb high zs & a second pump. The car is lite around 3000 with in it. I will be at reynolds next weekend with the alky cranked up.
Great run, i think I have reached my limit. Think my car runs faster on drag radials. When is Reynolds?
