New bolt-in 9", Centerline wheels, MT tires
Michael McCoy
I've got a new bolt-in 9" housing that needs a new home. It's also an all new unit & not a 30 year old housing that's been welded up in the backyard. It's set up to handle as much stress as any TR can put to it w/a backbrace already installed as well as internal gussets in the centersection mounting area, laser cut brackets are used for the upper control arm bushing mounts/for the lower control arm mounts/& for the coil spring mounts, & lastly it's got drain & fill plugs welded on. It's stock width for a G-body & you just need axles, brakes, & a center section to be set. It's currently collecting dust & $600 gets it.
I've also got 2 new Centerline Warrior wheels w/MT ET Drags already mounted on them. The rims are 15X8.5's w/3.75" backspacing & the tires measure 28X10.5" & they've got a little over half their tread left. $328 + the shipping fees gets the tires & wheels sent to you, so you're basically getting the tires for FREE :)
There's 2 almost new MT ET Fronts available too. They're 26X4.5" tires & $100 + shipping gets them.
Thanks.
It's got 3" tubes & I'll get a shot of it for you as soon as Nate's fever goes down from it's current temp of 104 :eek: Lisa will be home in 2 hours, so I'll send some over then. Thanks bud.
