New combo needed.....
fatride
Senior Member
I'm going to be chaging my combo since my new motor is broken in now. First, 009's are gone 60's are in. FMIC waiting to go in car also. Now Turbo and converter. This car will mostly be on the street. i was thinking of going TE63 with a 3500 L/U stall????? Or a TE45a??? What do you guys think of this combo? My overall goal is low 11's when i do go to the track. Rest of my combo is in sig.
That's more turbo then you need to go low 11's...stock heads no porting?? go with a 61 and a 3200 stall, it'll spool so fast you're head'll spin and go 10's if you want it to.
Heads have some work done, but more on the stock side. Will the 61 be better for the street vs. 63/45a?
I would say 63,45, or a 61. 11.00s will be easy with those turbos and still be very streetbable. You could probably go with a Art Car non lock 3200 with those turbos too. I have heard the 45A likes a 3500-3600 converter. Probably overkill turbo for your combo.
I recommend you check out a thread I started on the 6152 turbos..... sounds like a perfect turbo for your goals.
Thread
HTH
