I just invented a mod to move more coolant around in the 86-7 engine. At the back of the heads there is no coolant crossover, to move coolant between heads, and a small amount of air sits at the top of the heads. there are thick bosses on both sides of the intake above the coolant holes in the heads. i drilled them with a 3/16 bit through the bosses and drilled the tops of them larger to accept a 1/4 npt hose fitting. maybe the dipstick tube for the trans will need to be relocated slightly. i will connect 5/16 trans cooler line from these ports to the 2 ports in the heater lines that are unhooked from bypassing the throttle body coolant lines. this will help the coolant that normally sits at the back 2 cylinders and the air and push it out to the rest of the system. it doesn't seem like much but anything to even out the coolant temp across the 6 cylinders can help...
hope someone out there thinks its a good idea.
