new door install
smallv6
Still in Block Learn Mode
Has anybody installed new doors on there cars, If so how difficult of a job is it?
Thanks in advance
It's not to bad. Make sure you have some help, the doors are pretty heavy. Make sure to put in new pins and bushings in the hinges.
Toughest part is getting them ajusted. Just take your time. 11mm ratchet wrench makes the job ALOT easier.
Thanks! I will give it a try, I have my 11mm ready to start!
Use an engine hoist with nylon straps that way it holds it steady while you put it into position. I have done this a few times and this is the easiest way without banging the door into the fender.
