Turbo1dr
9 Sec Wanna-Be
- May 25, 2001
The statement "you get what you pay for" is NOT true. I have ATR headers to prove that!
SignUp Now!That crossover piece looked to be welded wrong because it didn't come anywhere close to lining up with the drivers side piece.: )
Have pictures now.....
I've been running my car a month or so with no problems so far. No track times yet. I replaced mine old stock ones because I was tired of welding them up. These are some of my issues for those thinking of buying a set.
1. Replace passenger side motor mount to lift the engine to the proper height to clear the passenger side control arm.
2. I had to shorten the stud on my turbo by flipping it around and grind the nut down for clearance.
3. Buy new Gbody DP. I have one of the original THDP but it didn't fit. It was time for some shine anyway..
4. Weld up the crossover at the slip joint. All lined up ok. Tried clamping but welding it is the right thing to do. I still can take it on and off.
5. I didn't use any gaskets, never have, except for the V bands joints. Slight leak without them. Still questionable if you need them or not. High heat silicon might have worked.
6. Center bolt on passenger side header was very hard to get too. Wrenched it on first then put the others in. I'm sure ATR's are the same.
So far no problems. Still need to make a few runs with high boost in it at the track to fully test them.
Today Andre is installing the ebay headers on Jason's 87 gold T. the brand is from Drift Pros, and every thing is fitting so far, but the cross over pipe is not line'n up. It is hitting the passinger side upper control arm and the pipe is running under the flywheel instead of between the flywheel and oil pan. The crossover pipe is going to have to be modified to fit.![]()
And the center bolt (header flange) on the passenger side is a @#$%^& to put on!!!!![]()
same here.. mine fit pretty good.. no issues with the crossover.. and NO LEAKS !i actaully liked them, had a very picky friend of mine look them over and he was imrpessed for the price and had no prob helping me get ready to fix the x-over..i think for the money its worth it
do they sound good?![]()
