This stuff is way to confusing.
Jdmmotorz - $175 + $35 shipping
Ad says T304 Stainless Steel
24 negative feedbacks in last month
14 neutral feedbacks in last month
Autopowerenterprise - $203 + $30 shipping
Ad says 321 stainless for the headers, just stainless for the crossover pipe
1 negative feedback in the last month
drift-pros - $169 + $36 shipping
5 neutral feedbacks in last month
Ssautochrome - $179 + $44 shipping
Ad says T304 and 321 Stainless Steel
12 negative feedbacks in last month
12 neutral feedbacks in last month
Not sure about the flanges and welds
There is an outside change that you will not receive them, and customer service is suspect.
Possible off-set bolt-hole problem
What % of guys on here have had to cut and re-weld? 50%? 75%?
Who has had them the longest and have any cracked yet?
According to Bill:
What needs to be done to these headers:
-The v-band style flanges on the x-over will not work, they are too short and the clamp WILL NOT compress them together when tightened. Yo need to cut them all off, buy 4 new ones and weld them on
-The x-over will need to be completely revamped, you will have to buy a stainless 90deg elbow and weld it in place of the one on the pass side because the angle is not correct.
-The pass header where it connects to the x-over has a 45deg elbow that needs to be cut off and moved because the angle is wrong.
-When you buy pipe to repair these discrepencies, you will soon figure out the sizes are all metric! Try to find that stuff in stainless!
TA Performance:
TA V2010CH Mild Steel Turbo V6 Header Kit ...................................... $ 645.00
TA V2010CH-Jet Mild Steel w/ JETHOT 2000 coating V6 Header Kit .. $ 925.00
TA V2010CH-SS 304 Stainless Steel Turbo V6 Header Kit .................. $ 955.00
