turbojay
- Feb 14, 2009
My GN is finally 100% complete with new engine / trans and other upgrades. Here is a list of things done to it in the last 2 years:
New Block:
1. 109 block .030 over
2. Blue printed race balanced
3. Steel crank
4. Steel rods
5. Forged pistons
6. 2 steel center mains
7. Disassembled, cleaned, all tolerances checked, fresh hone, re-assembled with new seal rings & new bearings
8. 212/212 Comp Roller Cam
9. New hi rev lifters, pushrods, timing chain
10. PTC 6262 Ball Bearing Turbo with .63 exhaust & ported S cover
11. Ported Weber iron heads, new exhaust valves, springs, retainers, locks, seals, & shims. Decked flat and cleaned up pedestals
12. Cometic head gaskets
13. Refurbished exhaust headers with new hardware
14. Precision SLIC intercooler (stock location)
15. PTC 2800 10” L/U converter
16. Extreme Extender chip
17. Siemens 80 lbs injectors
18. Billet adjustable fuel pressure regulator
19. HRParts motor mounts
20. Alky Control alcohol injection system
21. Powerlogger & Scanmaster upgrade
22. Fuel & alky pressure transducers installed and connected to Powerlogger
23. MTX-L Automotive Wideband A/F Gauge Kit
24. Autometer Sport Comp II Gauges
a. Boost / Vac
b. Water Temperatur
c. Oil Pressure
25. F-body radiator
26. Duel SPAL fans with new wiring harness
Transmission Upgrades done by Jimmy’s TransmissionsHDS Hardened Stator
Wide Alto red lined band
Shift Kit
Transgo pump ring kit
10 vain rotor (pump)
New pressure regulator valve
Line pressure regulator spring
Line pressure boost valve 0.500
2nd reverse boost valve 0.300
Alto race red clutches 3rd & 4th
Competition Valve Body
Pan Spacer & 700 4R Filter
Hayden Tranny Cooler
Big thanks to "TurbobuRick" for installing the above listed items and tuning the car. The car is running great.
New Block:
3. Steel crank
4. Steel rods
5. Forged pistons
a. Boost / Vac
b. Water Temperatur
c. Oil Pressure
25. F-body radiator
Shift Kit
