Just finished the install of new B2B FAST on a '89 Mustang 393ci N/A(using a White plug&play interface) and got the car running, even with a decent idle, but Actual AF reads only in the high 15.'s, except briefly when blip'n the throttle.
Using the "L" function, it has put VE values as high as 150 for that cell. When Closed Loop is enabled above 1500rpm, it still max's out the O2 Correction (+/-24.6 on a 25% max) This has only rev'd in the garage to 2500 or so thus far.
Manually increasing VE numbers at Idle from 70 to 95 didnt impact Atual O2 at all.
I have laser temp'd the headers and each tube is about as hot as the other suggesting that I don't have a dead cylinder.
I have inserted the O2 sensor in both sides of the h-pipe and similar results for each side. An exhaust leak at the shorty header/h-pipe is possible, but on both sides?? and how largeof a would it have to be?
The UEGO voltages match (connected and disconnected) as per the Manual.
So here I am with no further things to try. The only nagging thought is the small cam produced a lumpy idle with the stock computer that sure sounded a lot bigger - this always seemed odd - installed wrong?
FWIW, bought the car in current setup (sans FAST), drove well, was weak on HP but good on TQ (only run to 5K 360rwhp, 430rwtq), figured it had to do with the small cam to begin with.
Pls, any trouble shooting ideas are appreciated.
