Thanks for the replieseveryone,
VtheGNMan, Thanks for the Head torque explanation, that makes sense and I didn't know that.
V6sleeper, thanks for the parts list, wish I wouldn't have placed the order already
By the time your posts were made I had ordered some stuff from summit, Kirban and a few others. If you guys see any issues let me know, thanks! I got the following:
- Aeromotive 11169 Stealth Electric Fuel Pump
- Comp Cams 980-12
- E3 Spark Plugs ( ordered from summit but I figured they were pretty good as they are the only plugs listed on Kirban's website
- Trans Filter and other various gaskets that need to be replaced.
- Taylor Cable 64600 High Energy Spark Plug Wires.
- Power Plate ( as recommended by several people)
~ As for the Injectors and the Chip ~
I was looking at Turbo Tweak and they seem to be very good, I just had a few questions:
I was planning on upgrading the turbo and going to alcohol injection at some point in the near future... with that being said, I like the idea of the SD2 Chip Turbo Tweak has, I am very tech savvy and I like the idea of being able to tune cars with a laptop on the fly and all of that. I was going to go with the 60lbs injectors as they are capable of high 10s and are more than anything I would need. When selecting the chip from Turbo Tweak they ask several questions about what your turbo is and all of the necessary things they need to build your chip, my biggest question is should I wait until I decide on a turbo and MAP sensor before I buy the chip? or would I be able to reprogram the chip myself later on when I get the turbo?
On that note, is there any turbos you all would recommend? I am primarily looking at the Precision line of turbos, they seem to be very good.
I was also looking at a 3.5 in down pipe and a Precision Intercooler to fit in the stock location. Thoughts on those?
A Pro logger was also on my list of things to pick up as the SD2 chip requires it.
Thanks guys,
Cam
