I just put a set of 50# injectors in my car and need to know what to use for fuel presser? i was told to sart at 40? can i go up to 50 (with the vac hose off?)
If you don't know, 3 bar (i.e. about 43 PSI) is as good a place to start as any.
Yes, you can go up to 50 PSI, but shouldn't you have purchased larger injectors (e.g. 55's) to give yourself a little more breathing room if that's the case?
Fuel pressures are generally given as static (i.e. line off).
Originally posted by fast84gn I just put a set of 50# injectors in my car and need to know what to use for fuel presser? i was told to sart at 40? can i go up to 50 (with the vac hose off?)
Sure, if you want to flood the motor with gas. Up in wyoming, I would think 40 psi would be a good place to start with 50# injectors and your mods. you might even need to go lower than 40#'s. you won't know until you try.
I agree with UNGN, at our altitude you probably want to start at 40# unless you have had a lot of headwork done or are flowing a ton of air. I run about 42# FP with a TE44 at 22# of boost on 100 octaine UL.
