- May 27, 2001
Attached in this post is the latest firmware for the ISAC. This release has a change in the way the trim knob functions when use to control boost. Now the range of boost available with the trim knob will be from your base PSI to your lowest slider or launch PSI if you have the car in launch mode.
The PC software has not changed. If you are not using the ISAC for boost control or not using the knob for boost trim, there is no need to update.
Note that the version has not changed. This was just a quick maintenance release.
