scot w.
GNSperformance.com
- Feb 19, 2005
The GNS Line-Lock kit is here!
This kit includes a powder coated solenoid mounting bracket. This will fix the mounting of the solenoid on the inner fender well... The solenoid is completely rebuild-able and is designed to operate under extreme heat for optimum durability. The solenoid withstands 3,000-psi line pressure and is backed by a manufacture 1 year warranty. The Line-lock Activation Switch has a built in 10-amp micro-switch and a nice positive feel red actuator for a smooth release. Includes close to two feet of wire for easy installation. Also built in to the switch is a rubber mounting band that makes mounting to a shifter handle a breeze. This kit is made up using top quality parts including the bracket that is water jetted out and CNC bent then powder coated. The SSB brake line is also Teflon lined with top quality fittings.
** The Two Nicest features that set our kit apart form anyone else is our Stainless Steel Braided line to go from the solenoid to the master cylinder and our Solenoid Mounting bracket.. No More having to bend hard lines! and No more putting holes into your inner fender!
For more information or to purchase this kit, Please visit our web site by clicking this link--> GNS
